A crystal between XTAL and EXTAl uses the internal oscillator of the chip.
In this circuit teh NAND gates ar euses as Inverters (both inputs connected) and the inverters are biased to linear operation by the feedback resistors R49 and R50 (this is an abuse of CMOS inverters seen not seldom). These amplifiers and teh crystal in the overall feedback loop form the oscillator as described here. The output from IC6, pin 11 is used to clock the MCU.
I wonder why they elected to use an external oscillator? Perhaps to run the chip at a frequency that was outside the normal (frequency) range of the internal oscillator?
Usually, I only see an external oscillator used when synchronisation with another device is necessary.
The 6800 had a minimum clock frequency of 100kHz, possibly becasue some internal logic circuits used dynamic logic, not static logic, to save precious sislicon real estate?in theory I think it's possible to completely stop execution by freezing the clock
Thanks for that Harald. I've learned something new.The 6800 had a minimum clock frequency of 100kHz, possibly becasue some internal logic circuits used dynamic logic, not static logic, to save precious sislicon real estate?
