I have a need for a <100mA low-dropout regulator with an output voltage of 3.45V to 3.5V
It has to feed two modules, one with a minimum supply voltage of 3.4V, and the other with a maximum supply voltage of 3.6V. (Between a rock and a hard place.)
I'll be feeding it with a minimum of 4.2V or thereabouts. (3 x AA cells in series, which could drop to ~4.2V when close to flat.)
I don't want to specially order a low-power adjustable LDO regulator like an LP2951. I'll never need one again and this is a one-off. Delivery is free, by courier, (RS), but I wouldn't feel right buying just one, and don't need anything else right now.
So I've decided to use an LP2950-3.3 and jack it up by 0.15V. No problem, but I can't make up my mind which way to connect the output capacitor - between the output pin and the ground 'pin', or between the output and ground.
Either would work, but which is preferable? (Keeping in mind that an LP2950 is very unstable without a decent, low-ESR output cap.) >=2.2uF is recommended for the LP2950-3.3
Any input is most welcome. (Please pick A or B below.)
Edit: I modified the circuit - that current should read 3.3mA now
