I see that the board is made by Silicon TechnoLabs. Perhaps you could ask them about suitable programming software?Hello
I need help to find suitable software to program AT89s52 (look development board )
AT89s52 support Keil compiler , my Laptop have serial port , window
which suitable software is used to program AT89s52 ?
I got the solution If I use AT89s52 then, I need to buy USB ISP programmer because AT89S52 doesn't have serial bootloaderIf your board uses the same connections as the board on this page, you might be able to contact the author for info on the programming software. His email address is all over the page:-
http://www.kmitl.ac.th/~kswichit /tahan/boards51/Board S51.htm
I'm afraid I can't help there. I'm a PIC man. I just did a little legwork in the hope it would help you.Now I am using P89V51RD2. If I am not wrong. my compiler should be Keil and programmer software should be Flash magic ?
