Need Help w/ Custom Portable Speaker Schematic
Extra Syrup
Sep 29, 2015
11
Hi! I'm planning to build a custom portable speaker. I am hand crafting the casing from wood, and I know how I want it to look and operate, but I do not have the knowledge to design the schematic. Is anyone interested in working with me to create the schematic?
To give you an idea, here is the basic premise of the component setup:
There will be four 3 inch speakers housed in a wooden cube. There will be one 3.5mm aux jack. There will be a power switch and an LED light. It will run off of battery power that will also be inside the cube. The type of batteries used are yet to be determined.
It seems like a fairly simple schematic for an experienced person. Anyone interested in lending a hand?
Thanks very much! :)
Arouse1973
Adam
Dec 18, 2013
5,178
Hello
One important question, what are the wattage and impedance of the speakers you plan to use?
Thanks
Adam
Arouse1973
Adam
Dec 18, 2013
5,178
Now do you want the enjoyment of building a circuit or are you happy to have a module.
Adam
Extra Syrup
Sep 29, 2015
11
Adam
I'd definitely like to appreciate building a circuit from start to finish. Plus, whatever I put together has to fit within the 4 to 5 inch cube that will house it. Each speaker will be mounted on each of the 4 sides around the horizon of the cube.
Extra Syrup
Sep 29, 2015
11
Arouse1973
Adam
Dec 18, 2013
5,178
The schematic is in the datasheets I sent you with all the other components. I don't quite understand your response.
Thanks
Adam
Extra Syrup
Sep 29, 2015
11
Thanks
Adam
I apologize. I do see the various schematics, but none of them seem to exactly match my particular situation. I'm a super noob, so I just need a little more hand holding. ;)
Arouse1973
Adam
Dec 18, 2013
5,178
Please elaborate on your situation? I don't understand.
Thanks
Adam
Extra Syrup
Sep 29, 2015
11
Thanks
Adam
I'm essentially looking for someone who knows circuitry well enough to put the schematic together based on the components that I know I want to use. Four 3 inch speakers, 1 power switch, an LED (power indicator), and a battery. As to any other components needed to tie all of that together, I look to the expert for the inclusion of those components into the schematic.
If I'm not making sense or this sounds ridiculous, just let me know. Haha :)
Arouse1973
Adam
Dec 18, 2013
5,178
Well the main component Martin is the amplifier. You will need those components first and you build the circuit and attach the speakers to the output, being they are the same you could have two parallel lots of two in series giving you 8 Ohms. Although the amplifier can drive much lower impedances I would stick to 8 Ohms.
Adam
Arouse1973
Adam
Dec 18, 2013
5,178
Sorry I just called you Martin for some reason :confused:, I am tired, I am off to bed!
Adam
Martaine2005
May 12, 2015
5,314
Is this of any use to you?
It's made from readily available modules.
Martin
Extra Syrup
Sep 29, 2015
11
Adam
Thanks for the explanation! :)
