LED Addition
zhewitt
Jan 1, 2016
10
I am working on a circuit that requires 3 leds to light up. I want to have it so each time a high (or low it doesn't matter either way) signal is received another light comes on until all three are lit up and then the setup can be reset to do it again.
zhewitt
Jan 1, 2016
10
Let me clarify a bit, the leds are to represent the number of times a number was guessed incorrectly for a game I am making. Each time a choice was guessed incorrectly I wanted another led to light up to signal that the guess was wrong. the leds would keep lighting up every time someone guessed incorrectly until all three were lite. I don't know how to make the circuit that would add the incorrect guesses every time a high input was received.
Gryd3
Jun 25, 2014
4,098
Off the top of my head... probably a decade counter xD
Everytime it gets a pulse, it will 'count' up. You may need additional pieces, but this will serve as a good starting point. (Note, they can be chained together if you need LOTS of LEDs)
zhewitt
Jan 1, 2016
10
I had 3 decade counters and unfortunately two are now in use and the other disappeared. Is there a way I can recreate a counter with gates.
Gryd3
Jun 25, 2014
4,098
There sure is.
What kind of gates and quantities do you have on hand?
zhewitt
Jan 1, 2016
10
I have nor gates 1, nand gates 3 ,or gates 4, and gates 2
Gryd3
Jun 25, 2014
4,098
haha. That sounds like an interesting project, but I cant work it out for you right now.
Counters are incredibly easy to make with JK flipflops...
