tinkerpunked
- Jan 11, 2016
- 1
- Joined
- Jan 11, 2016
- Messages
- 1
I am hooking some LEDs into a picture frame. I’m running them on 12 volts. I want the option of either using 8AA batteries or a 12 volt power adapter to plug into an outlet. If I hook the batteries and adapter in parallel, when plugged into the wall, I imagine it would still drain the batteries, but at half the rate as if it was running on only batteries…is this correct? And how would I hook it up so that when plugged into an outlet, it would bypass the batteries and use only the adapter, saving the batteries. Is there a simple circuit that could do this?
Thanks.
Thanks.
