Koford (Slot Car) Bench Power Supply Project
Gryd3
Jun 25, 2014
4,098
Okay, I did try lowering the voltage on the internal pot down to 8v, but it still seemed to jump around too much when dialing the voltage in...
I will try going even lower to fine the sweet spot!
Thanks,
-TheChad
Did lowering it help the jumpiness any?
Something else it could be, is the potentiometer not cleanly adjusting... I'm sure you've had a volume knob create static as you turned it before.
You will have a pretty good idea if this is the case if limiting yourself to lower voltages does not help.
TheChad
Sep 23, 2014
114
Maybe a little, but not really...
I lowered the voltage all the way down to 4v and the precision of the external pot is still not there...
I think that's the problem really, the pot is just not precise enough for small incremental adjustments...
-TheChad
Gryd3
Jun 25, 2014
4,098
-TheChad
One last thing to check.. does the voltage jump around as you adjust the 'internal' pot?
If not we can say for certain that the external you have is not smooth enough, or travels too roughly to give a gradual change in resistance..
If it jumps with the internal pot as well, it may be the voltage regulator not adjusting smoothly.. otherwise, I think it's time you find a smoother moving external potentiometer.
TheChad
Sep 23, 2014
114
No, the internal pot moves in .01v increments, but it's a "infinity adjustable" pot, it doesn't have a start or stop.
If I turn the set screw quickly on the internal pot, it will jump a little, but that's to be expected..
-TheChad
TheChad
Sep 23, 2014
114
Any idea what kind of transformer this is? 4 outputs?
Thanks,
-TheChad
What does it say on the board where the windings are connected?
Gryd3
Jun 25, 2014
4,098
VA1, VA2, VB1, VB2
Two separate coils.
Does it provide you with any numbers anywhere?
Both coils could be equal sizes, or different sizes. Regardless, it's nice to have.
Think of it like having two transformers in one ;)
TheChad
Sep 23, 2014
114
No numbers or marking on it anywhere. It's blown. I am trying to replace it for a friend.
I believe it's 8-10a 10v, so maybe 2x 5A 10v?
I have not been able to find anything like it yet. Does it have a trade name?
Thanks,
-TheChad
Gryd3
Jun 25, 2014
4,098
Thanks,
-TheChad
If you look at the board, you may be able to determine how the two coils are wired... they could be two 10V 5A coils in parallel, or two 5V 10A coils in series...
I'm not familiar enough to know a name unfortunately, but if we know how it's connected, perhaps we can find an alternative that isn't so unique.
TheChad
Sep 23, 2014
114
The power supply is small, I'm guessing they used that type of Transformer because it's smaller that a 10v 10a transformer..
73's de Edd
Aug 21, 2015
3,730
Sir Chad . . . . . .
I'm tuning in late on a quite progressed thread . . .BUT . . . .
By using creative thinking to "get your money for nothing and your chicks for free", you could save yourself some of your
"hard earned munneys" and use your already " paid for" . . . . . .and quite heavily, I might say. . . . .Power Transformer,
with but a slight modification to it
I am no stranger to changing transformers to my needs or even winding them myself from scratch.
Now, that extends back to the "olde tymes" when they were almost exclusively constructed as shown below:
In that manner of construction the primary winding was the very bottom winding and then there was an insulative barrier and the secondary winding was wound above, and on top of the primary winding.
That transformer secondary is our point of interest.
If I needed less voltage on a secondary winding, all that I needed to do was carefully remove the protective fish-paper outer insulation over-wrap and then a bit of waxed paper wrapping and I would then see the exposed enameled wire of the secondary winding.
Now, on YOURS, its using split bobbins and upon that secondary windings exposure, it should looka- like-a- 'dis.
The working room and access on this type of transformer construction below, is a dream.
So with a methodical procedure of progressively taking off turns will let you get ANY lowered voltage that you want.
Be it that mentioned 10 VAC or the lowest mentioned 8 VAC.
Now . . . HERE . . is where I need my assumption, being confirmed by you, that the transformers center tap wire is sitting there taped up and unused / unconnected.
Since I am seeing a Full Wave Bridge rectification manner, being utilized.
If you have not progressed too far, would you want me to fill you in on that simple transformer procedure . . . .if so, let me know.
Reading about your " resistor located and connected to the '350's".
It looks to be one of the two voltage divider resistors that you are needing if wanting to make a LM350 output adjustable, it, along with the companion frontal adjustable pot that you are presently using.
For your " touchy" adjustment of that pot, look into finding a surplus one of these, of that pots value, and use it . . . . .it takes TEN turns, count em', TEN !, to go thru its complete ohmmic adjustment range . . .
now . . . . . talking about VERNIER adjustment !
http://www.mouser.co.uk/ProductDetail/Bourns/3590S-1-502L/?qs=ka0oSW1bB1L/KiVO5%2b8CPQ==&gclid=CObE0qe6vsoCFQ8taQod8DQCFA
(Since your "Earth" location is quite broad geographically, look it up again on the proper site and note that this is data on a a 5k but 1 k's are also available.)
73's de Edd
