thyristor vs triac
cjdelphi
Oct 26, 2011
1,166
I'm posting this mainly for others, but after a few searches and ebay seller listings many people seem confused...
While looking for resources to read, most people seem to interchange or use both "triac" and "thyristor" like they are both the same component!
And to add to confusion "SCR" well a sillicon controlled rectifier can be a triac or thyristor right?
In short thyristors allow ac to flow in 1 direction, triacs allow ac to flow in both directions, search for thyristor circuits and you'll indeed find triacs not thyristors but a lot of people seem to confuse the two which confused me lol
Minder
Apr 24, 2015
3,561
Both the GE SCR manual and the RCA manuals both refer to Triacs (bidirectional triode thyristor) and SCR's as part of the Thyristor family of semiconductors.
M.
Tha fios agaibh
Aug 11, 2014
2,253
Basically, SCRs and thyristors are for switching dc and triacs for switching ac.
A believe "thyrisor" is just a fancy name for a high current SCR.
So a triac and a thyristor are not the same components, but a scr and a thyristor are essentially the same.
Minder
Apr 24, 2015
3,561
GE were the first developer of the Triac after the SCR development (patent 3,275,909), and they termed it a Bidirectional Triode Thyristor.
I have the 6th edition of the GE SCR manual, 1st edition 1st pub. 1958.
They refer throughout to SCR's and Triacs as thyristors devices.;)
M.
dorke
Jun 20, 2015
2,342
What's in a name?
Before the semi-conductor period,
"name calling" started with Vacuum-Tubes or Valves.
As in so many fields we have the Greecks to blame for;)
They where named by the number of the Electrodes :
DIODE : DI-ODE ,Di for dual or 2 ,ODE short of electrode
TRIODE : TRI-ODE ,Tri for 3
TETRODE : TETR-ODE ,Tetr for 4
PENTODE : PENT-ODE ,Pent for 5
Then there were the ones named by "functionality"
MAGNETRON :Magne-Tron ,Magne for magnet,Tron for Electron.
CYCLOTRON :Cyclo-Tron, Cyclo for cycle (circle)
THYRATRON :Thyra-Tron ,Thyra for entrance or gate.
then came the semis named as follows:
THYRISTOR :Thyr-Istor ,replacing Tron(from Thyratron above) with Transistor (Thyra+Transistor)
TRIAC Tri-AC : TRi for 3 pins ,AC for Alternating Current
DIAC Di-AC : Diode for AC
S.C.R Silicon Controlled Rectifier a controllable diode( for DC).
Personally,
I prefer not to use Thyristor and prefer
SCR for DC and Triac for AC.:)
Minder
Apr 24, 2015
3,561
Personally,
A Triac If used on DC has to be commutated off, they are just as readily used in AC such as SCR bridge for one etc.?
Also SCR used back to back for AC use to simulate a triac.
I guess those that develop them, get to name them.;)
M.
Tha fios agaibh
Aug 11, 2014
2,253
Seem silly to me to use generic names like thyristor or vacuum-tube when referring to components.
It's like walking into a grocery store and asking for a can of vegetables.
dorke
Jun 20, 2015
2,342
M.
Absolutely,
SCRs are used in AC application.
The inventors do it lovingly like naming a new born baby...;)
dorke
Jun 20, 2015
2,342
Well ,
Imagine asking for a "Modern Aladdin's Lamp";)
here goes a true gem,enjoy:)
Tha fios agaibh
Aug 11, 2014
2,253
Those confounded newfangled inventions. Lol
(Good video but could only stand about 5 minutes of it)
sureshot
Jul 7, 2012
234
I thought a triac was two thyristors back to back in a single package ?
cjdelphi
Oct 26, 2011
1,166
Thyristor is a general group of transistors that includes SCRs TRIACs, SCSs and such.
À SIlicon Controlled Rectifier (SCR) is going back to William Shockleys 4? Layer diode is a general group of transistors but a thyristor and triac are not the same thing even though they're both SCRs
PAFMElb
Mar 20, 2017
11
Can't agree with that.
An SCR is a thyristor. A Triac is a thyristor. SIDACs, DIACs, SBSs (Silicon Bilateral Switch) and PUTs* (Programmable Unijunction Transistor) are also usually considered in the thyristor family.
In general thyristor refers to any 4 layer semiconductor with a negative resistance characteristic. Often the term thyristor is (incorrectly) used as a synonym for a Silicon Controlled Rectifier (SCR). So... An SCR is always a thyristor, but a thyristor is not necessarily an SCR.
*Note that a PUT is waaayyy different from a true Unijunction Transistor (UJT). Totally different technologies. It just happens that PUTs are (were?) used as a replacement for true UJTs because their behaviour when used in trigger circuits was similar.
