Herschel Peeler
- Feb 21, 2016
- 401
- Joined
- Feb 21, 2016
- Messages
- 401
Getting to play with Junction FETs, discovering them as a current source. I had three on hand; 2N3819 N-JFET, PN5433 N-JFET and 2N5462 P-JET. I did the attached exercises in the configurations shown in the schematic. Each exercise means building it with all resistors, 10 ohm to 1 M ohm and noting Drain current, Source Voltage and calculating mho. (See the exercises.)
Doing the exercises and comparing my result to the data sheets was interesting. We discovered what makes one different from another.
Applying this theory ...
2N5462 was chosen. 5 mA was desired. Referencing the exercise that called for a 270 ohm resistor.
In the schematic, lower right drawing. I tried to set up a four LED constant current driver. My drive side had the expected 5 mA. I was expecting all four outputs to also be 5 mA. A four output current mirror.
Okay, not the first time my design didn't work as I expected. One output drew 4 mA, the other three about 3.8 to 3.9 mA. It didn't matter which LED was where.
I am running on a breadboard with a 5 Volt regulator, about a 250 mA current limit (LM78L05 with a 2N4403 booster).
So, any ideas on what went wrong? Why were they all not 5 mA out?
