I am to design a switched mode psu without IC components.Help please
dorke
Jun 20, 2015
2,342
Thank you very much for your help. The link you put also looks very very helpful. The name of the course is Electronic Circuits I
That specific name doesn't mean much.
Could you post the syllabus of the course .
Oluwatimilehin
Apr 12, 2016
21
Diodes and Diodes Applications
BJT analysis (AC and DC)
FET Analysis
Transistor Amplifiers
This is basically all I am covering this semester.
dorke
Jun 20, 2015
2,342
Did the course cover BJTs and MosFETs as switches?
Have you covered Schottkey diodes?
What about about op. Amps?
Edit: What about differential Amplifiers ?
Oluwatimilehin
Apr 12, 2016
21
1) BJT and MosFETs as Switches: Its been mentioned but not in depth.
2) Scholkey diodes: Nope.
3) Op amps: Nope, thats for next semester.
4)Differential Amplifiers: Nope
Oluwatimilehin
Apr 12, 2016
21
I have been in electronics for 50 years and I would not know where to start with a switch-mode design.
Even a practical circuit would take weeks to design, build and test and modify.
That's the IGNORANCE of most teachers.
I sent letters to 2,300 IT teachers in Australia with a set of kits and projects. I got 19 replies 18 months.
I asked WHY?
Because we haven't a clue how to fix a project if it doesn't work.
Yeah it sucks. I wish I had a choice.
Oluwatimilehin
Apr 12, 2016
21
This is the sort of thing I am thinking of. This is how your block diagram should look. This is an example only and your blocks may differ and some blocks you may not implement on your design.
Adam
Hi Adam, I decided to go with designing a buck converter circuit per a recommendation here and I found a few helpful resources. I have been using this( http://www.arrl.org/files/file/QEX_Next_Issue/Jan-Feb 2013/Dildine.pdf)material and I have been able to calculate my inductor value. However when it got to the value of my output capacitance, I found this (http://www.ti.com/lit/an/slva477b/slva477b.pdf) material because the formula is clearer.
My problem here is that there is a value of ESR that I need to get, I have no idea how to get that value and I seem to have searches all over. Can you please help?
My parameters are:
Vin= 220v;
Vout= 15v;
I(load) = 1A;
Duty Cycle = 15/20 = 0.0682;
F = 50hz.
Also, is a buck converter circuit a regulated circuit?
Thank you.
Arouse1973
Adam
Dec 18, 2013
5,178
Hello, The ESR of a capacitor will be in the data sheet for the capacitor you choose. A buck convertor is only regulated if it has feedback into the control circuit so the PWM can change to allow for different load currents.
Adam
Oluwatimilehin
Apr 12, 2016
21
Adam
Thank you. Do you think a flyback converter can be used here instead of a buck converter?
Arouse1973
Adam
Dec 18, 2013
5,178
Flyback convertors are a buck boost, do you need that? Also they have isolation from the transformer, I guess you will need this with your design. So you decide. If you don't need boost then go for a forward converter.
Adam
Oluwatimilehin
Apr 12, 2016
21
Adam
I think I'll go with designing a forward converter.. I have been looking for some help online on how to go about it but everything seems to be going way over my head. Do you have any recommended tutorials?
Arouse1973
Adam
Dec 18, 2013
5,178
Hello, no sorry I don't have any tutorials. I would recommend purchasing a book on SMPS design.
Adam
