Looking for cheap ammeter that measure the smallest amp
dante_clericuzzio
Mar 28, 2016
33
I am looking for an ammeter that capable to measure the smallest of amp like 5 miliamp to 100 miliamp. Is there any cheap one kindly advise...if anyone knows
dante_clericuzzio
Mar 28, 2016
33
Any cheap DMM should be able to measure down to <5mA and up to 200mA or more with reasonable accuracy.
Actually i have a DMM and the price is not so cheap to me but i would say mid-range...and it cannot measure current below 0.1 amp that's why i asked
davenn
14,484
How can you guarantee that it can measure and display 5mA to 50 mA ? please confirm
did you look at the scales on it ?? somehow I think you didn't
have a look and see that it has a scale that goes down to 200uA
Dave
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
Or how about this one. Just place a one-ohm resistor in series with your load and measure the voltage drop across it. Measures from 0 to 199.9 mA with a one ohm resistor in series with the load. Requires a 12 V DC wall-wart power supply.
cjdelphi
Oct 26, 2011
1,166
Because you can adjust analogue meters with a screw driver i find them quite accurate...
dante_clericuzzio
Mar 28, 2016
33
Dave
I have a multimeter that have that kind of scale like 200uA and it does nothing...so by seeing i dont really believe until someone have tried it and tell me...
dante_clericuzzio
Mar 28, 2016
33
Is it possible that it only works on the 10A range?
If that is what is happening then you have blown the fuse in your multimeter.
Oh that's interesting yes it only work on the 10A range... it could be the fused blown off i never thought of that later i will open and check the fuse inside
