HellasTechn
- Apr 14, 2013
- 1,579
- Joined
- Apr 14, 2013
- Messages
- 1,579
So am i. There must be something we are missing here. Why would it work fine and then burn when i remove and re attach the rs232 inputs ?
Great find! That certainly is a mind blower! I'm putting those links in the same folder that I keep the MAX232.he he, well take a look here :
http://electronics.stackexchange.co...3232-overheating-burnt-after-connecting-to-pc
check the last comment.
Yes. If you scroll down that page you can also find this link :
http://e2e.ti.com/support/interface/etc_interface/f/392/t/233847
Only because i wanted to make our project as reliable as it can be, so i thought "signal conditioning" would be a good idea. I couldnt imagine this chip can fail that easily.Personally, I never understood why you thought you needed it.
I has actually able to transmitdata serial data from the picaxe to the PC without a MAX232. I only had to remove the 180 Ohm resistor that picaxe uses on serout pins.It would make sense if you were transmitting data from the Picaxe (0 to +V logic) to an RS232 port (±V logic) but you're not.
Most probably but would the chips actually bare the MAXIM logo ?I wonder if it would not be more likely a counterfeit batch that got out?
Constantine, did you repeat the tests the last post on the stack exchange mentioned to check for resistance on the pins?
Yep, they would. That's why it is called counterfeiting. Big problem with semiconductors sourced from Asia. Not just Rolex watches and Gucci handbags anymore: everything is counterfeited in Asia. Quality varies, but always caveat emptor. Even authorized distributors have been scammed. Only way to tell if its the real deal is to decap and compare with a genuine article, sometimes using very sophisticated techniques such as scanning electron microscopes. Only the guv'ment and the military can afford to do this. The Chinese in particular are rapidly advancing their semiconductor fabrication technology, so some of the counterfeits are quite excellent. They just don't have to bother with paying for original design, quality control, or royalties to the originator of the device that is counterfeited. Has a pretty nice effect on their profit margin.Most probably but would the chips actually bare the MAXIM logo ?
They are trying to do something about it, both technically and diplomatically. It is a serious problem best discussed in a new thread rather than this one.That i didn't know. So in other words companies know that their products are being copied and sold as original but can do nothing about it, right ?
I read 5.2K from pin 8 to 15 and the same value from pin 13 to 15. That is correct but also i get a 38K from pin 8 to pin 16 and an other 38K from pin 13 to pin 16 which according to the chip's block diagram should not be there.
From pins 10 and 11 to pin 16 i read nothing (open circuit) while i should be getting a 400K reading.
All measurements taken from unused chips.
After measuring the used chips i have got pretty much the same readings.
This is a reply to a much earlier post on this thread, but I doubt it will be "one last thing"...one last thing ..... a serious omission ... you show lines crossing and others that are "T" joints
I will start such a thread when I know more about the problem, but to answer your previous question, more data averaged over longer periods of time does not appear to be the answer, although post-processing is routinely used. The "best" solution seems to be to use CORS (Continuously Operating Reference Stations) to augment and correct your local GPS. A CORS station has a precisely known (surveyed) location for its GPS receiver, so any pseudo-distance errors between the GPS satellite and the ground station, caused mainly my ionospheric and tropospheric variations affecting the time-of-flight delay, can be measured by CORS and corrections broadcast.
In my South Venice Florida location there are at least three CORS, each transmitting corrections on at least an hourly basis, some more often. Two of these (McDill AFB and Ft. Myers) are very nearly on a light-of-sight that comes close to the property, so perhaps that will be of some benefit. I just don't know enough about it yet. But I will be following your work on this thread!
They should be according to the block diagram.How are you getting 38k ohm reading between your receive in pins? Are they not isolated from Vcc??
I have no idea.Assuming that your incoming RS232 feeds are not part of this circuit how are they coupled?
E-bay chineese seller !!!Your next readings have again two failed channels, for unused chips I would think you have a bad batch or a counterfeit batch.
Where did you buy these from?
There is a schematic drawing convention, probably invented because of the "disappearing dots" problem, that crossing lines NEVER represent connections. ALL connections MUST be "T" connections. If this is rigorously applied there can be no misunderstanding of what connects to where. Of course it takes a pretty good proof-reader's eye to vet a complicated schematic for adherence to those two rules.
Who's on First? may offer additional ambiguity in certain situations, mainly confined to baseball.![]()
Oy!E-bay chineese seller !!!
