Can you help me test a transistor
r2pee3
Oct 5, 2016
4
I have a mpsw45a transistor npn . I need to test it with multimeter to see if its good. When I use a multimeter to test it, positive on base and neg on collector I get a value however when I move the neg to emitter there is no value. I am a newb so maybe I am not doing this correctly. Thanks
BobK
Jan 5, 2010
7,682
I assume you mean using the diode test function of your multimeter, correct?
If so, you should get something like 0.6V on both of those connections. If you get nothing with the base positive and emitter negative, the transistor is bad.
Oh, and welcome to E.P.
Bob
r2pee3
Oct 5, 2016
4
Hello Bob,
I bought 5 brand new transistor and all of it are testing the same. I have it set on diode test fnction.
Thanks
BobK
Jan 5, 2010
7,682
Are you sure you are identifying the pins correctly?
What kind of transistor?
Bob
Audioguru
Sep 24, 2016
3,656
The datasheet from Motorola shows the schematic of its insides and its pins.
It has one silicon junction between its base and its collector with a forward voltage of about 0.65V. It has two silicon junctions in series between its base and emitter with a total forward voltage of about 1.3V that your multimeter diode test might not show.
Colin Mitchell
Aug 31, 2014
1,416
You need to put the transistor in a circuit with a 12v car globe (one of the globes for the inside light. )
Put 4k7 on the base and the 12v rail. The lamp will illuminate.
If it was a normal transistor, the lamp would not glow.
This is a Darlington.
r2pee3
Oct 5, 2016
4
That explains why. Thank you very much
