I am trying to work out how a charging circuit for a Ni-MH battery pack is operating and determine why there are powder deposits on one of the terminals of the cells of the battery pack. I have been told that the unit is new so I'm surprised that one of the cells has powder on the positive contact - perhaps due to overcharging? The 4.8V battery pack consists of 3 x AAAs in series.
The charging circuit is essentially a zener diode and J3Y transistor. The anode of the zener is connected to ground and the cathode is connected to a 100 Ohm resistor. The other end of the resistor is the input voltage of ~7.7V which is also connected to the collector of the J3Y transistor. The cathode of the zener is connected to the base via a 0 Ohm resistor.
The voltage to the base is ~6.3V and the voltage at the emitter (battery positive terminal) is ~5.6V.
There is some sense circuitry on the input and battery positive rail based around an ST 393 connected via potential divider resistors. The outputs go to what looks like a microcontroller of some sort. Possibly to flash the charging bi-colour LED and indicate when the battery is charged?
