I have a 400w ATX PSU that I want to drive an array of Peltiers. I would like to have 2 power settings, the 12v output and 5v output of the PSU.
My question is: can I simply have 2 transistors each with unique inputs (12v & 5v respectively) whose output is combined to the Peltiers? In this way either the 12v or 5v will be on and supply power.
Previously I have only made a setup where a single voltage is used (12v) and its wired so the transistor intersects ground from load and ground to PSU. This makes sense as there will be less power to handle at that end - this setup however may require transistors being between the positive output of PSU and positive input of Peltier. Can this be done? I am aware of leakage voltage issues too and am hoping diodes will solve this.
Failing that I presume a PWM setup using 12v is the only other option...?
Much obliged for any help!
