I want to design using by cascading 74*163 ic
Atakan
Dec 18, 2016
11
I want to design such as count at 33 start and run 77 reset.
Is it true my image?
Atakan
Dec 18, 2016
11
I want to design such as 33,34,35,36,37,38......74,75,76,77 and finishing.
secondly 33,34,35,36,37,38...74,75,76,77,33,34,35,36,37......
how can i do this? have you any examples about this tasks? i could not do it :(
is it true?
I'm sorry,. I can't understand what you want.
Arouse1973
Adam
Dec 18, 2013
5,178
What is 33 to 77? Please tell us more about your project.
Thanks
Adam
Atakan
Dec 18, 2016
11
Thanks
Adam
I have an exam. A question will be cascading counters and digital 74x163. Such as this is starting at count 33 and finishing 77 otherwise starting at count 0 and finishing 80
Etc. I could not do this question i could not draw with my hand. I am just doing 0- 15 at counting circuit
First you need to understand how to cascade the devices so you can count to a higher number than 15.
Then you need to understand how to load a number into them.
Then you need to work out the logic to decide if you have reached a certain maximum count.
You might want to look for an 8 bit magnitude comparator as that will make the last part easier.
Herschel Peeler
Feb 21, 2016
401
Pins 1, 2 and 9 have no input. Yes, they need to be connected together, but they need an input from something. The Preset inputs need to be either high or low, not floating.
If this example is good for you, I have most TTL and CMOS chips done up this way. I used to teach this stuff.
[MOD edited to place image into post]
