Super Simple Circuit questions
Jacob Johnson
Jan 4, 2017
14
Yes, I'm a noob. I just need a couple answers that I can't seem to find otherwise.
I'm trying to make a really simple and cheap (focus on quantity) circuit to turn on LEDs for a set period of time at the press of a momentary switch (push button, lights light up for 3 minutes or so, then turn themselves off).
So I need to know what I need to purchase, and how to put it together.
Arouse1973
Adam
Dec 18, 2013
5,178
You need a retriggerable monostable, these can be easily made using standard logic gates and some timing components such as resistors and capacitors, you should be able to find lots of circuits on Google.
Thanks
Adam
Herschel Peeler
Feb 21, 2016
401
Retriggerable? Why?
LM555 is okay and cheap.
Battery powered?
What LED did you have in mind?
Here's a starting point. With a 390K timing resistor I get about 2 1/2 minutes. With a 430K I get about 3 1/2 minutes. Specifics depend mostly on how close your 470 uF cap is.
Total cost for parts shown comes to less than $1.00.
(P.S. After playing with the circuit, the diode is not needed. Replace it with a wire.)
Jacob Johnson
Jan 4, 2017
14
Retriggerable? Why?
Battery powered?
Hey, thanks. At the very least, I can use your diagram.
So, I'm afraid I might not have been clear enough when I said I'm a "noob". I have minimal knowledge, at best, of electronics. I recognize a couple symbols in the diagram (resistors, capacitors, diodes, switch, and ground), but overall, it's really over my head (mostly your numbers). :/
I'm looking for a very simple and small circuit for about five or six small LEDs. With enough battery power to light them at full capacity for a good amount of time (many many cycles of approx. 3 mins)
It's possible I might be able to figure out what to do with your diagram (with help from my brother), so that's a great start. I appreciate the help.
Any further clarification would also be appreciated.
just which parts I need (exactly what to search for) and in what quantities. Aside from that, I'll figure it out. ;)
Thanks, again,
Jacob Johnson
PS: Also thank you to Arouse for trying to help, but unfortunately, half your reply went directly over my head, and the rest was meaningless without the part I didn't understand. :/
Jacob Johnson
Jan 4, 2017
14
Oh, I should probably add that the circuit should be very compact and self-contained (ie: portable and completely encased)
Harald Kapp
14,306
Get a kit like this or like that?
Build it into a case of your own design.
Jacob Johnson
Jan 4, 2017
14
Idk, that seems a bit pricey for my propose. :/
Herschel's option seems more reasonable at a mere buck a pop. While those kits would greatly simplify the project (rather make it easier for me to do), I'm afraid it would turn out far too expensive, and tbh, those circuits seem a little excessive (I'm certainly no expert, but I don't think my circuit should require that many components (or maybe it just looks like more because of the green boards)).
Thank you, tho.
Jacob Johnson
Jan 4, 2017
14
I apologize if, by being so naive as I am, I am misusing the forums.
I would be asking a person like at an electronics store, but there aren't any out where I live. :/
Harald Kapp
14,306
If a kit is too expensive, you'll have to put up the circuit by yourself. See this example for example.
You don't that's what we're here for. Only it's a bit difficult if on the one hand you don't want to spend the money for a kit but don't understand Herschel's schematic on the other hand.
For more than one LED the schematic needs to be modified. You may have to add a driver to power the many LEDs.
What battery voltage are you goinf to use? This makes a difference. With a low battery voltage, you will have to put the LEDs in parallel, each with its own current limiting resistor, bu the total current will be comparatively high.
With a high battery voltage you may be able to put the LEDs (or at least some of them) in series with only one current limiting resistor. The total current will be less.
Power will be the same in both cases.
For more detailed help we need more parameters:
- operating voltage
- type of LED (diffferent LED types have different operating voltages)
- current per LED (depends on teh type, too)
Herschel Peeler
Feb 21, 2016
401
Thanks, again,
Jacob Johnson
Next step then. Attached is a data sheet for the LM555. It can be configured to create a string of pulses or a single pulse. Shown is the basic single pulse deign. Timing is controlled by the 470 uF capacitor and the 390K resistor. Pin 3 is the output. It goes high when the trigger input is taken low. How long it stays high depends on the R and C mentioned.
The output can drive over 100 mA high or low. So it can drive lots of LEDs.
For lower power there is also an 7555 that is CMOS. Same pin out and function but can't drive as much output current.
You can usually pick up the 555 for $0.50 or less. It has been around a long time and is really popular.
Battery powered? What voltage? The circuit provided would work fine down to about 4.5 V, up to 15 V.
Three AA or AAA batteries should last a long time, especially if you used the 7555.
How many and what kind of LEDs? I built it using a white LED, maybe 15,000 mcd (pretty bright).
No component values are critical.
  • LM555 d.pdf
AnalogKid
Jun 10, 2015
3,055
What is the project?
How many units?
How many LEDs?
How Bright?
Battery type, size, etc?
Size limit?
Cost limit?
How accurate must the 3 minute interval be?
Important: Do the LEDs have to turn off crisply, or can they fade away over 5 to 30 seconds?
Depending on the answers, this could reduce the electronics to one resistor, one capacitor, and one transistor. The problem is that 3 minutes is a loooong time for a simple R-C timer circuit of any nature, but your super-ultra-secret project requirements probably preclude a counter-based approach. At least no one has mentioned a PIC yet...
ak
Jacob Johnson
Jan 4, 2017
14
Okay, so now I have a better idea of what info you need. Thank you.
So I intend to have different units with different color leds (sometimes multiple colors). (idk if there's different info you need on what type, cause I know very little about leds I just need bright leds that shine constant in a specific color)
A maximum of six maybe seven.
Powered by AA batteries. up to 4, but the fewer the better. (2 is ideal, 3 is acceptable, 4 is pushing it, but prolly doable) (if 4 is going to make the circuit easier, I'll just do 4)
The brighter the leds can light the better.
Actually, fading out is perfect.
It's approx 3 minutes. Really that's an arbitrary number. it could be 2 or 1.5 if it has to be.
As for the project, I thought it not necessary to say, but I guess there's more to consider than I thought there would be. :/
I'm looking into making light up shape pillows to sell on etsy. The tutorials I've seen use really cheap-a$$ methods that look like dollar store quality at best, which is not what I'm going for.
I'm not very well versed in the technical terms in electronics, but I usually have a working understanding. The main thing thats throwing me off is the timer. If I'm told exactly what search criteria to use to find one (or better a link), I could probably figure the rest out by a schematic. (except I don't know what the vcc is oHo)
So as for price, it just needs to be cheap enough to be able to be competitive in my resale price.
Thanks again for all the help.
KMoffett
Jan 21, 2009
723
You will have to play with the R1 and C1 values for 3 minutes.
Ken
Added Note: the MOSFET should have been labeled NDP6020P for a P channel
Jacob Johnson
Jan 4, 2017
14
- operating voltage
Omg, idky I didn't check that circuit earlier. That seems so simple. I can do that. The only thing is I need to know what sort of adjustments I need for the parameters I mentioned above. (ie: 6 leds, 2-3 minute timer)
PS. Now I think of it, a 9v battery would work great.
AnalogKid
Jun 10, 2015
3,055
Other than flipping everything over to an N-channel FET (lower Rdson per $), Ken's circuit is exactly what I had in mind. Also, a 9 V battery significantly increases the number of MOSFETs to choose from.
ak
KMoffett
Jan 21, 2009
723
Jacob,
Q1 is a P-Channel MOSFET. (label should have been NDP6020P)
With 9 V you could do 6 LEDs.
AK,
That Mosfet was used for a 3V battery circuit. Changing the circuit for a N Logic level Mosfet would improve availability and cost.
Ken
Jacob Johnson
Jan 4, 2017
14
Jacob,
AK,
Ken
Ok, thank you. I think I've figured it out. This schematic is very helpful.
Thanks everyone for helping out so much.
--Jacob Johnson
The switch across the 1uF capacitor may not like the current from the capacitor. I'd put a 100 ohm resistor in series with the switch.
Jacob Johnson
Jan 4, 2017
14
Do you mean between the switch and the leds/capacitor, between the switch and the capacitor/mosfet/resistor, or like this:
(yes, I drew the circuit on paper, yes, I screwed it up, at first)
