Need help on digital speedometer fuel meter
Ralf Kalkuhl
Dec 13, 2016
7
The problem is that the meter always shows full even when empty i don't know which wire on the gauge is the fuel wire or if its integrated on any of the other wires, the float and sending unit is okay so i think it's either the gauge or the wiring, I converted it from analog to digital, the analog one had 3 wires which i think are 12v, ground and the sender wire from the float. I will include the manual from the digital gauge and the wiring on the bike harness
73's de Edd
Aug 21, 2015
3,730
Sir Ralf . . . . .
If your sender is being a variable resistant unit , it thereby seems like it is dependent upon the value of changing resistance being applied between the very two top pins of the connector which you have shown.
Try connecting a 100 ohm resistor between those two connections and see if the display then indicates a decrease in fuel level.
If so, then a 47 ohm resistor should show an even lower level of fuel on the display.
This confirmed testing would signify an open resistance loop between the sensor proper and those two connections .
73's de Edd
Ralf Kalkuhl
Dec 13, 2016
7
Sir Ralf . . . . .
73's de Edd
Thanks! i'll give it a shot.
