Hi Bluejets, thank you for reply, This is the only onformation I can find. The input terminal block has 4 inputs; vcc, ground,cth and ctl, Just the usual 3 for relay output; NO, common, NC. There was no documentation with unit. regards.
One Channel 5V Relay interface board,be able to control various appliances, and equipment with large current
With output indicator, can be directly microcontroller output
It can be controlled directly by Microcontroller (Arduino , 8051, AVR, PIC, DSP, ARM, ARM, MSP430, TTL logic)
Surrounded by fixed mounting holes, external connection use rotating crimping terminal, make connection firmer
Optical coupling isolation, input and output power optional independent control ( DC 3V )
Specification:
Materials: Metal, Plastic, Electric Parts
Size: Approx. 51x31x23mm/ 2.01x1.22x0.91inch
Pole Number: 1 Channel
Load: 10A
Remote Control Voltage: great than or equal to 5v
