Need a servo/motor and controller for a project
Mysticmayonaise
Jun 17, 2017
2
1GsUb
I am putting a paintball gun into a Nerf gun, and what I'd like is to have the paintballs stay in the rather large battery compartment, and be pushed upto the paintball gun through a tube.
I thought using some sort of stepper motor or servo and a controller/arduino to control the motor
Problem is, that since this is a mechanic paintball gun, it shoots once per trigger pull, then resets, so I cant have a motor constantly pushing balls to it, as they would jam or break.
So I need a way to push a switch (attached to the trigger) and have that cycle a single ball forward, then rinse and repeat per pull.
Suggestions for motors, controllers, and maybe a simple switch?
Thank you
Mysticmayonaise
Jun 17, 2017
2
how about a switch like this one ?
https://www.aliexpress.com/item/SA-...2471021675.html?spm=2114.40010708.4.25.LahPZD
will you be manually pulling the trigger ? if not then the arduino could send signal to some motor which in turn will pull the trigger and at the same time the arduino to signal the other motor to feed balls. You could use a pushbutton to order the arduino execute the above cycle.
Yes, the trigger will be pulled manually, and then hit the switch connected to the arduino
And I may have found a switch I can use, though the one you linked is perfect
