I have an instrument (A VDO Logic Combi) used for engine monitoring on boats. The LCD is water damaged, and I am assuming that it is a 16 x 1 display. It displays normal upper and lower alphabetic characters, decimal point, and uses block graphics to indicate fuel level via a bar. The LCD has a metal outer case 77mm x 22.5mm x8mm, thats just over 3" x 7/8" x3/8" and metal case has 6 lugs used to locate the case on the PCB (twisted to secure it). I have not yet attempted to remove it, but the only connections appear to be a ribbon type cable with two conductors at each end. It is located on the track side of the board.
On the upper side of the board is an PCF8578T display driver IC with the Phillips logo.
Can anyone identify the LCD (black on white), and confirm the connections? I assume it must be a serial interface.
VDO no longer support the instrument, current in 1995, and now out of production for 15 years or so.
