sommech7498
- Aug 13, 2017
- 4
- Joined
- Aug 13, 2017
- Messages
- 4
Hey guys. I'm new to electronics here and need help figuring out a circuit I'm trying to make.
I've attached an image below of the circuit I'm trying to make. Basically this is a tester for automotive purposes.it's a 12v circuit with a 100w rheostat/pot I'm using as a load. I will only be turning it on for a second or 2 max and really only plan on running 4-5 amps through it but want to be capable lf more if needed. I want to be able to turn on the transistor with a 9v and have the transistor and battery mounted on a pcb. I have 2 questions for this circuit. 1 is what kind of transistor should I be using. And 2 is how can I figure out what resistor to use for the transistor gate? Thanks for the help in advance.
