So even though the 12v LEDs aren't advertised as having resistors they do? Or should I add one to them just in case? Would a 560 Ohm resistor work for the LEDs? Also do the switches with LED's need resistors? If so would a 560 Ohm resistor work for these? Lastly, is there any hurt in adding a resistor to an LED that already has one? (Just incase I didn't realize it had one already)The LEDs in the switches may require a resistor. Some would have one built in, others won't.
You 12V LEDs have the resistor built in, so they are okay.
Bob
Also should I add resistors before the LED power input and the switch power input? If so would 560 Ohm resistors work?Thank you for your insight this is helping me a TON, would this look something like my drawing when it is wired? (obviously there will be more switches and LEDs in the final circuit)View attachment 37293
Alright I have figured a lot of things out thanks to you and others in this forum! Now my question is what kind of resistor will I need to protect an LED that can only run under 2.2v from a 12v power supply?The LED lights you linked are intended for direct connection to an auto electric system, which runs 12-14V. Adding a 560 Ohm resistor would likely make them very dim.
The switches you linked appear to be a mixed bag.
Bob
