I'm trying to repair a 1970 GM am/fm car radio that plays pretty well on both bands, but the audio distorts at high volume levels. I have two questions:
1. Could this distortion be normal? It sounds pretty good at moderate volume but when volume is at the top say 15% of it's range it distorts. Using a 1khz tone my scope shows distortion beginning when the 10ohm speaker is driven above about 1.25 watts. Any guess as to how many watts this should be capable of with minimal distortion?
2. The 11.7v power supply driving the audio amp/output stage has high ripple when volume is high. Using the 1khz tone I can see a 1khz ripple of about .6 volts P-P. I can't find anything wrong with the PS and I have another similar radio that works better and that seems to have a similar ripple. Although that 2nd radio will also eventually distort at the very top of the volume control range. So, Is this ripple typical or acceptable?
3. I'll probably have to replace the entire audio stage with a modern audio module. I'm looking at a module based on the
TDA2030A chip, but I am open to any suggestions. I'd like to keep the radio original, but it may not be worth the effort.
Thanks
Frank
Thanks
Frank
