Hi all, new to the forum,
I am trying to rebuild a motor in a Hamm's beer rippler. This small motor rotates counter clockwise at 1.45 RPM. The motor works when running. The problem is every once in a while when plugged in the motor will not start. It makes a noise like it wants to run but sits in stasis. When this happens I can turn the shaft which is connected to a magnetic disk and it will start turning again and run.
My problem is that it is enclosed in the sign and I would have to take it apart to get the motor to start it which turn the scrolls on the rippler scene. Not an option. A replacement motor is $75.00 which I prefer not to spend if this can be fixed.
The motor is I believe an AC permanent magnet 'stepper' motor (I am not an engineer or electronics specialist so am guessing on a lot of this). Here are the specs:
Age - I'm guessing the mid 1960's
Brand - HANKSCRAFT Company
Manufacturer - Autotrol Corp.
Model - PX-100
60 Cycles 3 Watts 120V
1.45 RPM Counter Clockwise Rotation
The magnetic disk sits on a shaft above the windings. When power is applied to the motor the disk starts to spin which turns the shaft mounted on the magnetic wheel with a gear on it.
The stator (the prongs connected to the windings?) is magnetized. The stator prongs on the top of the plate section which when put together slips between the slots in the bottom stator. These are also magnetized. Is this normal? The reason I ask is that older watches become magnetized and have to be demagnetized. Could this cause the occasional lockup of the wheel at startup that the stator has become magnetized?
Also the magnetic disk seems to wobble a bit when spinning. The bushing/shaft is oversized which I presume is to allow freedom of rotation. The whole moter vibrates some and makes what sounds like what a bad bearing would sound like.
I have included pics along with this post. I can take more if you ask.
Any idea's or help would be greatly appreciated.
Thanks to all in advance,
Clark
Model - PX-100
Clark
