I have a transducer I want to use for something.
The part is a "bass shaker" type thing, basically the voice coil from a speaker. You attach this to a chair and connect it to a bass-channel output of an audio amp so that you can feel the bass better, but I'm just using it as a agitator to try to remove bubbles from a liquid mix. The bass shaker is a common inexpensive one stated as 50mm across and 30mm high, 4 ohm coil and 20 to 25 watts. The typical ranges stated for it are 20 to 80 Hz, but people say it will go as high as 500 Hz. To get the best effect out of the device it would need to be fed an AC signal, not just pulsing-DC.
My first thought is to just get a little "Arduino-style" DC motor driver, since apparently most of those let you reverse the motor direction when the voltage is still above zero. They use PWM to control the motor voltage (up to 12v usually) so both the frequency and amplitude could be controlled this way.
I'm thinking there might be an easier way however, but without building the entire thing from scratch. It would just be an analog circuit with a couple knobs to control the frequency and amplitude, from 20 to 500 Hz and up to maybe 6 or 12 volts?... It doesn't need to be precise in frequency or power, nor does it need to display the frequency or power.
I don't know what this might be called however..... When I search Google for "tone generator" all I get is results for telephone line testers. Is there a name for this thing, or a common (cheap-China) product sold that can do this?
