Transformer for Camera
R791945
Jun 19, 2015
92
I bought a motorised cam without its transformer. It is rated at 5v dc 2A. The nearest transformer I have is 5.99v 2A. Can I assume that I must match the voltage exactly and 5.99v risks damaging the cam?
kellys_eye
Jun 25, 2010
6,512
Make/model/link to item? The 5V seems 'suspicious' - does it have any controlling electronics inside?
kellys_eye
Jun 25, 2010
6,512
A 'cam' is an irregularly shaped disk usually used to operate movement. This ridiculous shortening of CAMERA to cam is misleading hence my request for further information.
As it stands you will need a 5V 2A power pack. Anything other than 5V will likely damage that camERA.
Why would you purchase it WITHOUT a transformer anyway?
R791945
Jun 19, 2015
92
It was very discounted from a reputable shop and I can take it back if it does not work.
I have been looking for a switch mode charger. Is that overkill and so should i settle for an ordinary charger?
Audioguru
Sep 24, 2016
3,656
A transformer produces AC that is completely different from the DC needed by the camera.
The DC must have a connector with the correct + and - polarity.
KMoffett
Jan 21, 2009
723
5VDC/2A is no problem. The correct connector with the 5VDC wall wart will be more of an issue.
Ken
