I have a gillet that is heated via a Li-ion battery back [7.4v, 5200mAh, input
C 8.4V1.2A Power: 15W Max, Resistance Load :5ohms - 200 ohms. It has 4 adjustable smart outputs]. I have 2 batteries one active, the other is charging and switches with the active one when its charge has dissipated.
There are 3 separate heater elements within the garment. They input into a connector near the battery pocket where they are narrowed down to just two flexes going to the battery unit. Each heater element's pos. are connected together, likewise for neg.
I have used a resistance tester to check if there are no further breaks in the cable and I am getting a 0 reading ie no resistance.
When I put a battery into the gillet I can switch on the battery controller. A led lights up to show it is supplying current to the gillet. Within a short time the led goes out and the battery will not turn on again until it is recharged.
I also have a jacket with sleeves and it takes the same batteries as the gillet, but it does not turn off quickly on connection.
Can anyone suggest what could be causing the gillet to stop being supplied with the battery's current and thus not getting heated.
