Hi to all,
Please bear with me as I try to describe my needs.
First a bit about myself: I am wheelchair dependent as a result of failed spinal surgery.
O.K. What I want to do is to power the dash camera in my self drive car from two separate supply points from one 12v battery.
Supply 1: Being from the back of the cigarette lighter socket via the AUX position on the ignition to a 12v to 5v converter. I know how to wire this.
Supply 2: Direct from the 12v battery to the 12v to 5v USB converter. I know how to wire this.
What I don't know: is how to stop the battery direct supply to the converter and the ignition AUX to the converter from back feeding each other. (i.e. the Aux circuit becoming active when the direct supply from the battery is used and vice versa) I have been told that this could be achieved by using 2 Schottky diodes wired into the positive leads from both supplies. If this is correct what value would these Schottky diodes need to be? I have no information on what amperage/current the dash-cam draws.
The reason is that my dash camera has WiFi for transmission of the recorded video and I want to be able to download the video without having the laborious act of entering the car and have the ignition on AUX whilst doing so. Downloading time is dependent on video capture time and this can sometimes take an hour or more.
I had achieved this in my Van by using a remote controlled switch (but this drained the battery over a period time as I don't drive very often)
I hope this makes sense.
Thanks Ray
Thanks Ray
