Michael Studio1
- Jan 5, 2018
- 494
- Joined
- Jan 5, 2018
- Messages
- 494
Michael, If I remember correctly, your problem was the 7v supply to ic801 was only 3.5v.
Either something downstream of D800 is overloading the supply, or the ps is unable to deliver the required current.
There are several approaches to finding the culprit, I like to use an isolation method to finding things but discretion should be used that it won't cause component damage.
You could use an external supply to inject the 7v into just that section to see if that gets pulled down also. Which would prove the ps side is ok.
Many ways to skin a cat.
I'm signing off now to have a cold one.
Regards, John
Perfectly correct., John, Thank you for your comment. Much appreciated. it was indeed the +7V. not arriving at pin80 of the IC801. If those 1N4007's are OK and don't need replacing (bang goes another few GBP), looking at the Cct Diag. (page 114) and comparing it to the -8V. which does arrive at its pin 52 of the IC801 as -7V., the circuitry is much the same. This is indeed a 'puzzler'. I shall obviously have to don my wizard's steeple and go into a corner and think . . . . In the meantime enjoy your 'cold-one' could be an ice cream or a shower!. Best wishes,
Michael Studio1 UK.19:30 GMT
