Michael Studio1
- Jan 5, 2018
- 494
- Joined
- Jan 5, 2018
- Messages
- 494
VERY strange. Yes, Bushtech, the UNI-T model UT61E battery is OK. I checked it with my other questionable DVM - the HoldPeak HP-9804. and it reads +9.4V. The UT61E is still questionable though and for the reason that when powered up with no test probes in and Volts selected (this setting gives DC reading unless the blue button is pressed - then it goes into AC setting). The oddity in the DC setting (with no probes in) is that sometimes it shows a Neg. sign before the readout - then that disappears and all is well. Right now it is reading as it should - so I'll make another round of the 'Tagged Test Tails' on the AVR and include readings from the Thandar TM531 Digital Multimeter and post the results here:Meter's battery OK?
All readings are referenced to AGND CN101 pin 5 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . UNI-T UT61E . . . . THANDAR TM351 . . . . . . . . . . . . .
CP13A pin7 SIDE_CON B'D. . page 111 . . = +8.16V. .. . . . . . . . = +8.11V . . . . . . . . . . . . . . . . . . .
. . " . . pin6 . . . . " . . . .. . . . . . . . ." . .. . . . . = -7.829V. . . . . . . . . = -7.89V. . . . . . . . . . . . . . . . . . . .
CN14 . pin15 . . . ." . . . . . .. . . . . . " . . . . . . . = +6.858V. . . . . . . . .= +6.78V. . . . . . . . . . . . . . . . . . . .
CN101 pin1 . .REG_CNT 1/4 . . page 110 . .= +14.22V. . . . . . . . .= +14.2V. . . . . . . . . . . . . . . . . . . .
IC 103 pin1 . . . . . . " . . . . . . . . . " . . . . . . . = +6.386V. . . . . . . . . = +6.3V. . . . . . . . . . . . . . . . . . . . .
. . " . . .pin3 . . . . . . . ". . . . . . . . . " . . . . . . . .= +6.61V. . . . . . . . . .= +6.53V. . . . . . . . . . . . . . . . . . .
IC 104 pin1 . . . . . . ." . . . . . . . . . " . . . . . . . = +3.6V. . . . . . . . . . = +3.52V. . . . . . . . . . . . . . . . . . . .
. . " . . pin3 . . . . . . " .. . . . . . . . . " . . . . . . . = +4.3V. . . . . . . . . . . = +4.22V.. . . . . . . . . . . . . . . . . . .
IC 105 pin1 . . . . . . ." . . . . . . . . . " . . . . . . = +8.168V. . . . . . . . ..= +8.12V. . . . . . . . . . . . . . . . . . . .
. . " . . pin3 . . . . . . . " . . . . . . . . . " . . . . . . .= +5.121V . . . . . . . . = +5.07V. . . . . . . . . . . . . . . . . . . .
IC 107 pin1 . . . . . . . " . . . . . . . . . " . . . . . . . = +0.002V. . . . . . . . .= -0.05V.. . . . . . . . . . . . . . . . . . . .
. . " . .pin3 . . . . . . . " . . . . . . . . " . . . . . . . .= -7.838V. . . . . . . . . = -7.9V. . . . . . . . . . . . . . . . . . . . .
IC 106 pin1 . . . . . . . " . . . . . . . . . " . . . . . . .= +14.15V. . . . . . . . .= +14.14V. . . . . . . . . . . . . . . . . . .
. . " . . pin3 . . . . . . ." . . . . . . . . . ." . . . . . . .= +8.169V. . . . . . . . . = +8.13V.. . . . . . . . . . . . . . . . . . .
That's it. I hope it makes sense and that I can continue to the next step. Are these Voltages as expected?
Signal Tones. Once more I am injecting 700Hz into VAUXR and 500Hz into VAUXL. These Tones are getting through the CX4 ffc cable and into the HDMI_B'D - but no further. Reason: only +3.59V at IC801 pin80.
Michael Studio1 UK12:05GMT
