Michael Studio1
- Jan 5, 2018
- 494
- Joined
- Jan 5, 2018
- Messages
- 494
I have found the reference to the Test Points - I knew it was there somewhere: Service Manual , Page 56. ADJUSTMENT Audio Section.
Congrats on getting power supply back up!I have traced the L&R tones into IC30 (page130) and can go no further..Originally 'twisting' the PCB 'cage' would cause the Right tone to appear..
So, what was the problem all along, D801?
It's always a plus to understand what happened, so we can learn from it.
I'm not very knowledgeable on digital either, but I'll help where I can.
Ic30 puts out a 24 bit digital stream on pin 9 called DataD. From there it goes to Dir/Audio PLD section. View attachment 39833
Originally, twisting the pcb caused the audio to come back. I would look meticulously for solder joints, hairline fractures of traces and component legs cracked.
You might get lucky and find the problem without having to go down the digital rabbit hole.
Page 33 shows the path going to HDMI boards. Ic22 eprom.AUDIO PLD (I wonder where that is?)...all those bracketed conductors go TO DIR/AUDIO PLD - I cannot work out what that is ..
I suggest you change tactics and try another approach; working backwards from audio output, instead of trying to follow the complex digital path from its origin.
Thanks, Bushtech, I'm not sure how the endoscope can be utilised - but it's truly amazing and was extremely useful in placing my sharp probes on those small pins. Michael Studio1 UK 22:16GMTThis is where your Android endoscope could be invaluable
Thanks, John - that was one bad PCB! Good, helpful illustration of what to look for. Michael Studio1 UK 06:23Look for dry cracked solder joints like this.
Sometimes you'll see slight concentric rings that are a tell tale sign of a bad joint. View attachment 39863
(Image courtesy of Google)
View attachment 39909 Looks like IC29.
Digital comes in on pin 14 and outputs analog on pins 1 and 2
Hello John - When first testing this AVR I was using Chassis GND - that was a mistake - as I discovered. All Voltages (other than Relay) are taken with respect to Agnd. I was getting all sorts of spurious readings until I appreciated this. Audio readings, however, may be different? Sorry about the complexity of my Test Point Facts: It was intended to enable anyone with a copy of the Service Manual to follow - page-by-page. Even I couldn't follow it without that! (I tried) You make a Very Valid Point! (about removing test points which I have wired in.) I'll first try removing them - just to see if . . . " it goes away " Until I get the AVR to stay 'ON' I can do further checking - and those 'TaggedTestTails' are the only foreign things on the AVR. I have nothing attached anywhere else. So. Out with the soldering iron! Michael Studio1 UK 10:28GMTI believe its going into protect mode because it is sensing an overload.
Make sure your speaker impedance isn't too low. I'd disconnect all external wiring to see if problem goes away. (No external shorts)
If it continues to switch off (with no external connections), there must be an internal short or the circuitry that monitors current or temperature is throwing a flag.
I'd guess it's that lost left(?) audio channel thats overloaded (shorted) and that's why it turns off after 5 seconds.
Your one post with all the test point facts was a bit hard to follow. (too much info for me to digest) Let's stick with basics for now.
Do you get any analog audio output from pins 1 and 2 of Ic29 with respect to Agnd?
(I don't know if you can within 5 secs)
.... How about with respect to some of the other ground references?
