Circuit symbols Identification
MFRANK
Aug 26, 2018
4
I have an old Amp circuit schematic which has symbols on it that make no sense to me. Can anyone with knowledge of these please help with a description of their meaning/connection. The symbols are lines connected to circles and ovals connected to a line with another line going through that oval. I have not been able to find these symbols on any search. I have included a pdf file with the symbols on it to assist you in identification.
  • Circuit.pdf
Minder
Apr 24, 2015
3,561
That is an indication that the conductor has a shield and the conductor is connected to it.
M.
davenn
14,471
You had better clarify that bit for the OP, it doesn't quite make sense ;)
the way you have worded it infers that the centre conductor is shorted to the shield
which, of course, isn't correct
MFRANK
Aug 26, 2018
4
Thanks for the reply Mider, but your pictorials (seen these Previously)or explanation has made me none the wiser and I still think you missed what I was trying to find out. From what I observed on the amp connections, shielding has nothing to do with it. Sorry.
duke37
Jan 9, 2011
5,364
The symbol you show looks very like the symbol for 'shielded wire or coaxial cable'. Are you sure that the cable has no shield?
Post a picture of the appropriate cable with connection.
Minder
Apr 24, 2015
3,561
The device the wire is connected to appears to be a phono type jack, these typically are wired with shielded cable!!
M.
davenn
14,471
well if you think we ALL are misunderstanding what you are referring to
THEN PLEASE enlighten us and red circle the specific part on the diagram that you are referring to
TILL THEN NO-ONE ELSE RESPOND
MFRANK
Aug 26, 2018
4
20180827_091501.jpg I have posted a picture of the connections. So please explain if these connections match the circuit for Sus & Vib/Trem inputs. I still think there is no shielding just 2 terminals per connections. Thanks to all that have posted replies.
davenn
14,471
OK,
It is wise not to tell us more experienced ones what you think we don't know when you don't know ;) ;) tends to be a little embarrassing ;)
so as we all said, the symbols in the circuit diagram represents shielded/screened wires
I have pointed them out on your photo and circuit diagram that I have annotated
firstly the circuit symbol from Minders collection
Annoting them in your circuit diagram
annotating them in your photo
Those 2 white cables and 3 grey cables all have screens
The grey cable on the far right is a twin core screened cable and from the circuit diag. appears to be the reverb socket
All the screens/shields will go to the 0V rail
OK so now that is clarified, is there still another ID problem that we can help with ? :)
Dave
MFRANK
Aug 26, 2018
4
Thanks Dave and others,
I see what you mean by screened now. I thought it meant 2 terminals with aluminium/meshed wire over the top of them, inside the plastic insulation material, but in this situation the meshed wire is being used as the other terminal.
Sorry for the confusion.
duke37
Jan 9, 2011
5,364
The screen may be connected at both ends and may be one ended only. Sometimes the neutral signal wire is connected to the screen.
In your picture at the bottom right show clearly three connections, others show only two.
Someone has spent quite a time on getting the earthing done properly to reduce hum.
