You could run JBL 100's off a little 1 watt amp. It just depends on how loud you want them.
yes 100 WPC is enough to cause you hearing loss. Is that your goal?
The thing is, get good speakers. Get an amp suitable for the size of the room and volume needed. You absolutely positively do not need to try to pair some amp that wrings the last wattage possible out of the speakers.
On the other hand, you don't want to ruin them by running an underpowered amp heavily into its distortion range.
Assuming the amp works correctly, hook it up and see if it has suitable volume for your needs before distorting.
Recommendation for just an amp is even more of a wildcard depending on your needs, budget, etc.
JBL was bought by Harman who was bought by Samsung. They have a new JBL L100 this year and its sensitivity is 90dB at 1W at 1m which is LOUD. If it is 8m away then you need 64W. If you want 120dB then you need thousands of Watts.
Editted.
Old speakers were designed to be driven from the fairly high output impedance of a vacuum tubes amplifier. The damping was poor and allowed a cheap speaker to sound boomy or a good speaker designed for it to have a loose flat low frequency response. But a modern solid state amplifier has an extremely low output impedance for good damping of resonances in modern speakers that causes an old speaker to have damping that is too tight and poor low frequency response.
I found a video of the Pioneer receiver and it seems to be much newer than the old speakers. Simply fiddle with the tone controls to make it sound the way you like.
I question your timetable, there were plenty of transistorized amps by the time those came out.Old speakers were designed to be driven from the fairly high output impedance of a vacuum tubes amplifier.
yes ... by 74 the vac tube was pretty close to being extinct outside Marshall Stacks and Fender twin reverbs.I question your timetable, there were plenty of transistorized amps by the time those came out.
