kellys_eye
- Jun 25, 2010
- 6,512
- Joined
- Jun 25, 2010
- Messages
- 6,512
Can you let us know what it is you're attempting to do? Where is this high voltage that you are curious to measure?
The high voltage I'm trying to measure is an estimated 10kv AC from a flyback transformer. I'm using the resisters for a voltage divider so i can see what the voltage actually is. I might just buy a high voltage probe at this point lolCan you let us know what it is you're attempting to do? Where is this high voltage that you are curious to measure?
Absolutely not.That leads me to another question, are liquid resisters (saltwater in an insulated tube, basically) a good way to contain high voltage (assuming it's long enough)?
I could supply you with one of those ROX-3, 30 Meg Resistors and a 1/4 Watt 3.0 K Resistor.
Both are Rated at 5 % Tolerance.
By my calculations: With 10 KV in it will be Close to 1 Volt across the 3.0 K, Assuming a High Impedance Volt Meter.
No Charge for the Resistors, Just $8.00 USD for the Shipping cost.
Or a $10.00 Canadian Bill.
I'll probably just go and buy(/make?) some high voltage resisters rather than deal with all that.
