Audiofreak1
- Sep 20, 2018
- 32
- Joined
- Sep 20, 2018
- Messages
- 32
ok now before I installed the new caps and I had a problem where it would make loud spikes of noise for two minutes. After that it was fine. Now I bought new caps and inrush current limiters. The inrush limiters I installed are sg26 5ohm 12 volt and the caps are 15000uf chemi con 105degrees 4 of them i put them in the same as I took them out. Put everything back together and plugged it in and both protection light came on for 2 seconds before I powered it on. The. I flipped the switch and all fuses blew except the small board with the transformer on it that’s the only fuse that did not blow. Check wiring somewhat I know I labeled everything and plugged it back how it was. I am at a loss here need some help. If anyone can help I would appreciate it.
