Ian Wallis
- Nov 13, 2017
- 23
- Joined
- Nov 13, 2017
- Messages
- 23
Hi all, I have a 100watt 18volt 5.55amp solar panel, to which I've fitted a 10 amp dual output battery solar charge controller, and two car batteries a 95ah & a 45ah.
1st question: if the panel is 5.55amp is this what the charge rate will be, or will there be more in the conversion?
I was using about 3 to 4 amps max from each battery (12volt sat tv & lights) and I was shocked at how fast they lost power; within a minute they were 10.5 to 11 volts.
2nd question: 12 volt, 3 or 4 amps should be nothing out of either of those batteries, right? or are the batteries duffers?
The batteries started to fizz like mad while being re charged and the 45ah which I always thought was good, now works at 10.5 volt. Grrrrrr...
3rd question: Even if the controller was on the fritz, how could it charge that badly if the panel was only 18volt 5.55amp 100watt?
Link to the controller:
https://www.ebay.co.uk/itm/10A-20A-...hash=item466bc9ff4b:m:mmdWKT4xEKteDljfMJEHG-g
Thank you in advance.
