Resistance + LED works on breakboard not on stripboard?
endlessparadox
Feb 14, 2018
40
Like the title says why?
Here are some pictures if it helps
I tried removing them from the breakboard to the stripboard like 3 times.I tried soldering all the cables even with the batteries cable.I tried without soldering.I tried putting the battery leads directly on the coppertrack.It refuses to work in the stripboard why?
Harald Kapp
14,272
You need to cut the traces on the stripboard where no connection is wanted. When you solder the leads of a component onto the same strip - as it looks you did - you short circuit the component by the copper track.
endlessparadox
Feb 14, 2018
40
wait have a hard time understanding it.
On the breakboard there is a line where electricity conduct isnt it the same on a stripboard?
Harald Kapp
14,272
Your first picture, not very sharp unfortunately, shows 4 solder blobs aka 4 component wires all on the same copper trace. Therefore the wires are all shorted by the trace.
Your second image isn't very helpful as it neither shows the orientation of the traces nor how the external wires are connected. Plus we do not know the schematic of the circuit. Do you want to connect an LED with a series resistor?
endlessparadox
Feb 14, 2018
40
just a resistor connected to a led.There is the resistor and the 2 led cables that go to the led.Yes in series
AnalogKid
Jun 10, 2015
3,045
On the second, topside image with the components, you need to indicate which direction the copper strips are going underneath.
For example, no matter which way the strips are running, the top end of the resistor does not contact anything else on the board except its own other end.
ak
BobK
Jan 5, 2010
7,682
It looks to me like you have an LED, a resistor, and two wires, with all leads connected together.
Bob
