WyluliWolf
- Sep 27, 2018
- 30
- Joined
- Sep 27, 2018
- Messages
- 30
I recently purchased a Samsung VCR/DVD combo player. I brought it home and it had no power
I'm trying to repair it and currently have another thread open as I work on it (HUGE thank you to those helping out, hopefully close to a solution).
Soon after bringing home the dead Samsung (before I thought to post on here to try and fix it) I found a Panasonic DMR-E75V VHS/DVD Recorder combo player. This is even better as it allows you to record VHS straight to DVD...well, it would if it worked.
This time I was at least able to plug in the player before bringing it home to make sure it had power! (Ha! Getting smarter I thought to myself). It DID power on but I was unable to do any other testing before purchase. Once I brought the player home I took off the lid and did a visual inspection. She was pretty dusty/dirty inside and I noticed 3 capacitors with issues. (See attached photo's). One is obviously leaking and two others were bulging. I've circled the two on the power supply side in red in the attached photo. The third capacitor was on the VHS side of the board (I can post a pic if needed).
I replaced the 3 bad capacitors, cleaned out all the dust/hair etc. and plugged in/ powered up the player. I then gleefully played some VHS tapes and DVD's with no issues for two days! Ok, there was one small issue. When I pushed the VHS tape into the player (gently) it would take the tape but then jam and eject before fully loading the tape. It was almost like the carriage would try to lower the tape before it was in all the way. A second try at loading the tape always seemed to work though, and once it lowered into place the tape would play perfectly with no issues. On day 3 I decided I would take the combo player to my work bench to see if I could determine why the VHS tapes were jamming. I unplugged the player (which had a display/clock when I went to unplug it) showing it still had power. I moved it to my work bench, removed the cover and plugged it in to do some testing. DEAD. Nothing, no lights, no reaction whatsoever, totally dead. I thought it had to be a coincidence since it just had power before I moved it! I tested the outlet I was using and it was fine. I tried another known good outlet, same results...DEAD.
The obvious glass fuse in the system is not blown. Visually everything else looks fine. I'm wondering if changing out those capacitors fixed one issue but then "blew" another part that was "on the way out". Attached is a closeup photo of the power supply side of the system with the new capacitors in place.
SUMMARY:
System had power initially but 3 bad capacitors were present.
Replaced bad capacitors with new, equivalent value, caps.
System worked 2 days. Was unplugged, re-plugged in and suddenly had no power.
I was unable to find a service manual for this system online, unfortunately. The user manual is readily available (although not overly helpful here).
I'd love to get this machine working again. I have a multi-meter, capacitance meter, soldering iron and a somewhat limited knowledge of electronics. (No fancy tools like an oscilloscope). Any advice welcome and I'm happy to provide more photo's, info etc. Thank You!
SUMMARY:
