KilgoreCemetery
- Apr 12, 2017
- 259
- Joined
- Apr 12, 2017
- Messages
- 259
At first, the protection relay would click on and off sporadically and I was able to trace the problem down to the driver board having voltage spikes in the signal path of one channel. The board mounts vertically, so I had this bright idea of removing it and putting it in the freezer for a minute, then reinstalling it and warming up the transistors with the tip of my soldering iron one at a time. Silly me, the cold must have killed whatever was working intermittently and now I have positive rail voltage in all sorts of places on the board that it shouldn't be.
-I've tested all of the diodes on the board and they are all good.
-I've replaced all of the electrolytic capacitors on the board because I plan on recapping the entire unit anyhow.
-I've replaced all but one of the transistors on the positive, "push" side, of the channel
-I swapped the remaining positive, "push" side, transistor out with the one from the working channel
I'm still getting about +58V in all sorts of places it shouldn't be. Including on the base and emitter of both the main push and pull output transistors for one channel.
It won't let me upload the service manual I found on HiFiEngine, but I do have a diagram for just one channel that I've been writing voltages on. Everything in blue ink is from the working channel, voltages in pencil are from the non-working channel.
Can anyone give me some ideas for what else I can check? I'm 99% sure that the positive rail voltage is leaking into the pull-down side of the circuit, but I can't tell from where.
