- Joined
- Jun 21, 2012
- Messages
- 4,986
@Alec_t: I bought an unheated Bosch O2 sensor years ago, thinking I could heat it to operating temperature with a Mapp gas blow-torch and learn a little more about how they work. Back in the day, my then employer, UDRI, was working on O2/CO2 sensors for a sponsored research project involving aircrew members. UDRI was purchasing very expensive sensors, which we technicians then instrumented and connected to an off-the-shelf airborne data acquisition system. IIRC, I never did fire up the Bosch sensor and run it through its paces, although I still have it out in my garage somewhere.
I am now using oxygen from an atmospheric oxygen concentrator, free courtesy of Medicare, because the ejection fraction of my failing heart is so low. Maybe now is the time to resurrect that O2 sensor and see how it works! Not too keen on mixing gasoline fumes with air (or oxygen) to put it through a workout however. I will let you know later if I decide to experiment and manage not to set the garage on fire or cause an explosion. Hmm. Maybe I could just mix some CO2 from dry ice to control the "richness" of the O2 sensor mixture.
