Hello, I am trying to repair my space heater. Basically, my heater sometimes will still heat even if switched off, or when I set the thermostat to a certain temperature and the actual temperature and readout is higher than the setting the heater will still stay on when it should go off. The only way to get it to trigger the relay to shut off the heater is to toggle the thermostat setting button.It's a Honeywell (KaZ Inc. HZ-709) oil filled space heater. See images:
