Okay, so to explain what I need help with I’m first going to explain what I plan on doing. I’m attempting to install led lights into my truck, the led light controller box is rated at 12v 1.5amp, I’m trying to tap into the head unit to pull 12v which is closest to where I want the controller box to be stationed. However if I’m correct the radio runs at about 5amps minimum, but if I tap into it would the leds only draw what amps is necessary? Or would the amperage be forced thru whenever say turning the radio up?
