haskellbob
- Apr 13, 2020
- 21
- Joined
- Apr 13, 2020
- Messages
- 21
Hello!
I have a Heathkit AR-15 receiver. I recently began having this problem: The volume control does not reduce the volume to zero, on one side only. The right side
If I turn the unit on right after turning it off, there is sound there at a pretty high volume, which drops after the "warm-up"), the volume hits a plateau and will not go below that.
There is a “null” spot in the rotation of the volume control potentiometer where the volume is almost zero. But that spot is not where the potentiometer is at the zero point; it’s at a place where some volume would be expected. At that point it seems like the proper volume control gradient takes over; from there on up the control regulates volume correctly.
Again:
The volume control does work once the volume in both channels is higher than the "volume that cannot be removed"... and from there on up.
I thought the problem was the volume control itself so I replaced it. To my dismay, the problem is still there. If the volume control is the culprit it means the new one is as defective as the one it replaced. That's hard to believe, although obviously it could happen.
I’m in need of a knowledgeable opinion.
Can someone help me out? I’ve drawn circles around the volume control on the first attached file. The second file is the entire schematic for the AR-15.
Thanks in advance for any help!
bob
Again:
bob
