Hello,
I have noticed that the ouput volume of the electric piano is much lower than it used to be. It does not have built-in speakers. With a headphone it is bearly audible, while with external powered speakers it is ok, but low. It seems that moving the volume slider past its midpoint (between the 5-10 marks) does not produce a noticeable change in output volume.
I suspected that potentiometer to be faulty and opened up the keyboard. Luckily there is an official service manual with electrical schemes included. But my measurements with a DMM showed that the stereo volume slider changes are going across to the output board correctly via the 2x3 wires.
And this is where my skills sort of end. I am not sure where to look for a fault on the output board, with many capacitors, two amplifier chips, a couple voltage regulators, and the output ports.
I've found a similar question related to the SP-250 model answered on this forum, this is how I found this place
The Korg manual is https://data2.manualslib.com/pdf5/104/10340/1033931-korg/sp200.pdf?d5bab82b522550709438da31578d5f70
any pointers are appreciated
thanks
thanks
