YEs: max. clock speed of the PIC18F4520 is 40 MHz (32 MHz using the internal PLL), so 480 Mbit/s is impossible to achieve (you'd need 240 MHz at least for this) and 5 Gbit(s is way out of reach. It's all in the datasheet.Is there a simple calculation that can help me?
HiYou can use any crystal you like because the PIC18F4520 doesn't have a USB controller onboard. Therefore you need an external USB controller and you follow the datasheet of that external controller to determine the required crystal.
The minimum clock requirements come from the basic facts of serial communication: If you transmit one bit per clock edge, you can at max. transmit 2 bits per clock cycle (disregarding higher coding schemes that can transmit more than one bit per clock edge). So 480 Mbit/s translates to 240 MHz.Please could you explain in simple terms the calculation of clock frequency to achieve these speeds, thanks.
