vcr head diag
Harald Kapp
14,271
@Audioguru :your reply is not helpful to the op's problem. He does have a vcr and wants to make it operational.
Harald Kapp
14,271
some tapes are having lines too
If some tapes are good, others bad, the head seems to be basically o.k. Tapes deteriorate with time. Anyway, cleaning the head is a good start and may improve readout of the bad tapes, too.
kerm007
Jan 8, 2021
10
the second hand i brougt is a JVC HR-J692U
very clean inside i will clean all the parts and see what will come up cause the first time with some original vhs tapes it was not super
Martaine2005
May 12, 2015
5,276
Just my 2 cents worth:
The OP wants to convert VHS tapes to DVD. Not use it to watch films.
I convert VHS, BETA and CINE for many people. It obviously helps to have working units.
Martin
debe
Oct 15, 2011
278
This is the correct way to clean a VCR drum & heads. DONT use cotton buds, use either strips of Chamois or purchase head cleaning sticks ( Chamois) & use Alcohol. Very important to clean in horizontal as indicated in picture, If you dont you may break the Head on the drum. Also make sure the drum is spotlesly clean aswell. Your fault is definitly dirty heads. Cotton buds can leave pieces that contaminate the head. If VCR tapes are stored corectly they will last for years, i still have afew that are 30 yrs old & still play fine.1.JPG 3.JPG 4.JPG 2.JPG
Martaine2005
May 12, 2015
5,276
I completely agree with the above procedure to properly clean VCR heads like a technician ‘should’.
However, watching mobile TV and VCR techs from yesteryear, this very rarely was done. A q-tip was used on 98% on machines.
Same as shorting caps with a big screwdriver!.
It’s wrong but works.
If cleaned carefully and gently, good results are usually seen.
Martin
bertus
3,835
Hello,
The methods shown at youtube and other video resources may not always be the best.
There are some blogs that are good, like the bogs from eevblog.
Those can be very informative:
https://www.youtube.com/user/EEVblog
Bertus
debe
Oct 15, 2011
278
I was trained to repair VCRs correctly as the customer was charged for a job done properly.
