Orcino, unfortunately no, still stuck with 4 beeps, error code translated from datasheet: Brown.
I am also also facing this problem 4 blinks/beeps, no help avaible on any forumNo, still waiting for any help...
@AljazG have you give feedback to board through bridge rectifier?? For VFA, VfB, VFCI am also also facing this problem 4 blinks/beeps, no help avaible on any forum
Just wanted to add, to avoid misunderstandings, that pin #7 I mentioned is the chip's pin, the actual connector pin is #22.You can see that, about the pin 7 (BET/BAT) issue
Roberto
Hi Roberto
Thank you for the given information. As you said you must omit resistor to ground and short pullup to vcc and it works. Indeed there is problem with BET pin info in original datasheet. I have used 6v feedback transformers and its working without problem.
Best regards
Aljaz
Hi all,
I'm back after a very long pause, and I see that other users have managed to build the inverter.
I'm attaching another schematic that is more accurate than the one found in EG8030 and this one worked fine for me. You can see that, about the pin 7 (BET/BAT) issue in my schematic the pin is indicated as connected directly to +24V (R29 short and R34 open)
The three small transformers are indicated as 220-12V and not 220-6V as someone did.
Also I'm attaching a datasheet of the exact components list, and later that day I'll post a picture of the jumpers configuration on EG8030 that worked for me.
Roberto
Hello,
Great thread! I was looking at a 3ph inverter for phase conversion and i happen to have 12kW of 48V telecom rectifiers.
My question is the transformer, i see you use a 24V nominally rated primary, or 34v p-p.
For 48V battery sitting at 40 to 60V DC, would the transformer be more ideally sized with a higher voltage input?
I assume there will be a "sweet spot"? Whats the calculation or rule of thumb for DC voltage and transformer primary?
I have a 3 phase 55-0-55 to 3 x (0-240) and i think the 55V primary is not going to be drivable from a 40-60v DC supply.
Many thanks, Stuart
Hi Stuart,
The transformer has to work at the lowest battery voltage, so all calculations should be based on this figure.
So for your minimum 40V DC input, which remember is peak to peak, you need a transformer primary winding of 40/1.41=28.57
It could even be a little less than that because there will be losses in the mosfets or igbt h bridge, and further losses in the transformer while under heavy load. So a 25V transformer would be good.
Here is 8030 english translation, unchecked.Hello everyone, You could translate sheet EG8030 using google translate, but you need to copy and paste each paragraph individually. Attached here is part of a translation I made for Portuguese (Brazil).
