Device turns off within a second of being switched on.
ivoltini
Jun 21, 2021
8
I am in process of troubleshooting an old gaming console which turns itself off within less than a second of being switched on. It has a built in internal power supply (12v, xx amp).
PSU is fully functional however it is showing 13.xxV instead of 12V. Could this be the cause why the gaming console is switching itself off?
Any help would highly be appreciated.
Thank you.
Martaine2005
May 12, 2015
5,276
Very doubtful.
How do you know the PSU is functioning correctly? just by the voltage?.
Have you measured the output when you immediately turn the console on? (before it switches off and has a load).
Martin
ivoltini
Jun 21, 2021
8
Hi Martin - I will have to run more tests to find out if the PSU is functioning correctly, I only tested the PSU output voltage. Will do more tests today.
Thank you.
73's de Edd
Aug 21, 2015
3,730
"old gaming console " . . . .now thats being as device SPECIFIC as " I'm a fixin' this a hear old car " . . .but at least that's a step up from Device.
BRAND AND MODEL . . . PUHLEEEEEEEZ !
