I have built the a guitar stomp box overdrive circuit. It works great. However, when I put it in ther box and faster the pots and guitar jacks to the box, and close it, it stops working.
The details of this build are in this thread:
https://www.electronicspoint.com/forums/threads/back-to-the-breadboard.295296/
I am thinking that maybe somethings touching the steel enclosure that should not be.
On the PCB , I have a length of bare copper wire across on e of the sides of the PCB, soldered in to act as a ground rail. I wonder if this rail is causing a problem. Or do you think it can be somethign else. The pots and the jacks do make contact with the steel box, as part of the fastening procedure, so I am not thinking that there are the issue.
What else can I check?
Thank-you
Thank-you
